Issue with installing call and SMS tracker
Effective from Android version 20.6 and above, the Call & SMS Tracking features are available directly through the LeadSquared Mobile App, which can be downloaded from the Google Play Store.
For devices running older versions of the app, users will still need to download and install the APK manually.
Please note:
On some devices, an error may occur due to Google Play Protect.
This can usually be resolved by disabling Play Protect via the Play Store settings.
On older devices where Play Protect cannot be disabled, a workaround is available:
Temporarily disable or force stop the Play Store.
Install the APK.
Once the installation is complete, re-enable the Play Store.
This workaround allows installation of the APK even when Play Protect cannot be disabled directly.
Related Articles
Admin unable to delete or edit the Leave Tracker added.
Issue: Admins are unable to delete or edit the Leave Tracker of users from settings. Explanation: The admin has added a leave tracker for some users as they will not be working on those days, but one user has returned to work earlier, so the admin ...
Two call activities of same duration and time is added upon Lead via SMS and call tracker App
Hi Team, Greetings!! Scenario: Two call activities are getting posted upon Lead with same duration time and activity time continuously. The calls are made through call and SMS tracker app. We checked the telephony logs and found out the time is ...
Only selected/Few SMS not being delivered
Hi Team, You can encounter an issue where one type of template will be sent properly via SMS and another template in Same account while sending can throw below error i.e "Invalid Credentials". First you may get success and queued response as below ...
Not able to play the call recording in a activity history tab | CTM
Issue Observation: We are not able to play the call recording through the activity history tab for the CTM Telephony. We are getting 401 unauthorized errors while playing the recording. RCA: This is because of the 2FA enabled for the Agency account ...
Issue with Kaleyra SMS Connector
Hi Team, Greetings! Issue : When we're sending a SMS Text from LS Account, where all the formatting is done correctly and alignment. Whereas, when SMS is received the formatting on the Mobile Device is not correct. Sample Images: With Default Value: ...
