Not able to Check-in and Check-out : SUD Life users
Checks/Resolutions:
1. Go to Manage users, check if the user is present.
2. Go to Manage users, check if the user is active.
3. Check if the correct branch is assigned to user in "Branch" opportunity.
4. Go to Entity > Lead details > Edit > Check latitude and longitude and present for the entity.
RCA:
1. The user is not present in the system
2. User status is deactivated.
3. The branch is not assigned.
4. Latitude and longitude are not present.
5. Latitude and Longitude are present but not correct.
6. Latitude and Longitude are correct, but the user's internet connectivity is not strong.
Action:
1. Request SUD POC for the mapping file to validate if the user is present in the file.
2. Request SUD POC for Latitude and Longitude files if manually shared by Client, and validate if details are correctly updated.
Issue persists after the check:
1. Check with the Client POC - Jyothi.Shetty@sudlife.in
(If correct details are shared by SUD Life to LSQ in the file.)
    • How to make 2 or more sales users see each other's leads via Sales Group
      Use Case : 2 or more Sales users should be able to see each other's leads without making them Sales managers. Solution: Assign the sales users to a sales group and make each of them as the sales manager of that sale group and make sure the below ...
    • SIERA Report Displays Only Reporting Users
      Issue In the SIERA report, the user was able to see only a limited set of users—specifically, those reporting directly to them. However, the customer’s requirement was to view all users in the report. Upon verification, we confirmed that there were ...
    • Users able to edit opportunity even after the opportunity is shared and only view access is given
      Issue: Opportunity is shared and the owner is also changed. Still, the user is able to edit the opportunity even after view-only access is given and edit access is restricted. RCA: The opportunity fields are not editable, but on the opportunities, ...
    • LEADS RE-ASSIGNMENT ON USER DEACTIVATION
      Issue : If a user has been deactivated, and the customer wants to retrieve all of the leads that were assigned to that user. However, this is not possible as in when user is marked as deactivate, we will not be able to apply any filter on manage ...
    • Not able to see captcha in the form
      Description: User unable to see Captcha on the form. Cause: Google captcha expired/invalid keys Resolution: Ask the cx to check on the keys and update the correct key.
