Agent Panel loading issue new UI
Hi Team,
Greetings!!
Recently we were encountered an issue where the agent panel in the new UI wasn't working and was displaying the below error
After communicating with the telephony team it was indicated that the reason for this was that the domain
marvin@leadsquared.com has to be whitelisted from the providers side as previous requirements only need leadsquared.com to be whitelisted
Related Articles
Agent Panel size issue
Issue: Agent panel keeps getting minimized or its size decreases unexpectedly. Root Cause: The panel width and height were set to 100 in the UTC configuration. Resolution: A value of 100 is too small — this configuration controls the panel size when ...
Agent Pop-Up Grid Not Displayed in NextGen UI for Existing Opportunities
Issue: The old UI displays an Agent Pop-Up Grid listing all existing opportunities in a tabular format in the agent pop-up. From this grid, users can select the required opportunity and then submit the configured dynamic form. However, in the NextGen ...
Lead page loading blank
Hi Team, You can face issue sometimes that everything on LSQ platform is working fine but for few leads, lead page will not be loading and a blank page will be loaded. RCA Most possible root cause for this will be email or name of the lead will must ...
Issue With the Page Loading
Scenario: Users experienced page loading issues in CRM pages using different networks. RCA: Please find below points 1. A browser extension was modifying the request by adding an extra parameter, which resulted in the page failing to load as ...
Form Fields not visible in New UI
Description: When a new field is added to Object Fields and subsequently included in a Form, the field is: ✅ Visible in the Old UI ❌ Not visible in the New UI Root Cause: This issue occurs due to a temporary sync or session-related glitch in the New ...
